stupid trim/radio removal question
Stinkwheel
Post by Stinkwheel »
OK, so.....................
i assumed that removing the 4 screws around the radio surround would allow that radio trim/surround bit to come out. Mine doesn't, the screws make it loose. I hate fiddly jobs, take the head off, no worries, but radio surround, WOAH!! hold on now.
I'm confused as im sure i had no trouble on my previous BX's, but the memory isnt what it used to be, so who knows.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
Undo the screws completely and take them out, it will just be stuck so will need some jiggery pokery to get it out as its probably wedged in at the back,but its just the screws that hold it in.
Stinkwheel
cripes, thanks. I 'thought' that should be the case.
Wonder whats going on holding it in ?
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Stinkwheel wrote:cripes, thanks. I 'thought' that should be the case.
Its the original radio I think so hasnt been out for a LONG while, could be the wires are jammed at the back?
Stinkwheel
yeah its the old blue spot bristol. (sorry Blaupunkt) my dad owned a car audio/security business for 25 years so im familiar with old radios :)
I shall be keeping it to one side to stay with the car but i cant be doing without decent -ish music ability.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
x 103
If its the original radio, then i've seen some on a BX with a long thread out of the back which is pushed through a bracket on the car and can then be bolted in. You sometimes need to remove the front lower tunnel trim to get at the nut (10mm?) to free the radio, other times you can reach round the back and undo the nut.
Stinkwheel
that sounds likely the way it feels vanny, i shall investigate further, i just fiddled about at tea break at crappy work.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
