As per title, I've got 7 but just need the other 9 or possibly just 5 if I was to get some locking wheel nuts.
Regards
WANTED: Speedline Alloy Wheel Bolts
- Mike E (uk)
Echoing Bandit,
the bolts on BX CX XM alloy wheels are the same, and have the washer and flat base.
the bolts for the BX steel wheels are much shorter and have the taper base and no washer. I expect the XM and CX are the same, but I have never worked on these which did not have alloys fitted.
You cannot get it wrong, it is obvious when they are incorrect.
The only thing to look out for is the shorter bolts used (I think) on the AX,
which would only have a couple of threads in the bx hub hence unsafe.
Mike
Mike
- BX Bandit
- Backslash Bandit
- My Cars: Cars
- x 3
Echoing Bandit - that\'s me. I have to go via a proxy server to get on here since the webfusion event. It seems to like putting in \\ when I use an apostrophe and prevents me using smilies (sad) and clearly does the odd double post (annoyed). Any way, must dash, I need a (wee)
