I have an opportunity to buy freshly overhauled D6C engine without loom and ancillaries. I want to swap it with my DFW, retaining ECU, loom, lambda sensor etc. from DWF and block, head, sensors from D6C.
Will it be "best of both worlds", or is there any possibility that somehow these elements won't match?
will it work (D6C + DFW)
akarso
1993 BX GTi 16V Auto
1993 subaru legacy turbo
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
I have an older DFW engine fitted to my car which originally shipped with a two row ECU (ie no knock sensor, square engine harness connectors), it now runs from a three row ECU without any problems. So i can't invisage any problems running a D6C with a DFW loom, in terms of sensors etc the engines are fundamentally the same.
Might be worth asking the same question on BX16valve.com as there are more european users who have performed all manner of changes to there valvers.
akarso
well, D6C is older than DFWVanny wrote:I have an older DFW engine fitted to my car which originally shipped with a two row ECU (ie no knock sensor, square engine harness connectors), it now runs from a three row ECU without any problems. So i can't invisage any problems running a D6C with a DFW loom, in terms of sensors etc the engines are fundamentally the same.
I am not sure if knock sensor has a mounting point on D6C block. I'll ask at the valvers forum, thanks.
The knock sensor can be fitted to ANY alloy block XU since it replaces one of the main bearing cap cross bolts on Number 3 bearing.akarso wrote:
Can be found just inboard of the oil filter.
It is, definitley, I was there when I removed it from the car!Vanny wrote:Probably, your more likely to know than me. I keep forgetting its an older engine than the shell.
