LHM cap breather (?) tubes- where does the back tube connect
stefanwhite
Post by stefanwhite »
hello british street surfers!
on my LHN reservoir cap are two transparent plastic lines. The one towards the front of the vehicle is in place but I can´t find the connection for the tube that goes towards the rear. Any suggestions? The modell is 17RD ie 1789ccm diesel 1992
thanks
1992 Citroen BX 17RD Millesime 115,000km
1994 Citroen AX 14D 246,000km 72mpg
1992 Citroen BX 14IE 146,000km
If I remember correctly it leads nowhere. It's an overflow I think.
Post by kiwi »
Philip Chidlow wrote:If I remember correctly it leads nowhere. It's an overflow I think.
Your memory is correct it just gets slotted into the wing.
Grüß dich Stefan, where are you located in Austria? I am in Germany, not too far from Bregenz, in the Bodensee area.
it is just a breather/vent pipe, which usualy goes through a small hole in the inner wing along side the strut top,
