The 1st is either a stretched throttle cable or the pedal box has cracked. I've got a spare pedal box which is fine (as far as i can tell) & throttle cable.
The 2nd is a consistent lhm leak which i think is coming from the octopus (i've got an octopus in my stores), deffo one of the pipes entering the front height corrector (i think i may a new one of these as well in my stash). Another leak has sprung up as well, no idea where from (but the lhm is now running onto the driver side wheel), but constant topping up of lhm for some reason doesn't seem to fix the problem
The 2nd issue above will deffo cause the mot fail
I'd be extremely grateful if there's anyone out there who would be willing to help, distance at this point is probably not an issue. Cash is available, no problem. Or can anyone recommend a good garage that's either near to me (nr chesterfield) or perhaps one further away if they are dependable & actually affordable?
Thanks guy's....
