Creaking/groaning from front corner
rob-81
Hi
My TZD has been making a strange and worrying creak from the front right corner. It creaks when breaking (with the car moving or stationary) and is getting louder. I have tried to accurately pinpoint the noise but am unable to be more specific than saying it is coming from the front strut/suspension area. It only occurs when breaking. It has recently had new ball joints on each side. It went back to my local specialist recently for something else and I asked him to have a quick listen to the noise. He was unable to identify it’s source then but it has worsened since then. I am going to book it in for another look over but in the mean time, any ideas?
Thanks in advance,
Rob
19 TGD estate
17 TZD Turbo hatch
17 TZD Turbo hatch
Linegeist
These noises can be hard to track down - as soon as you disturb the suspension, the noise stops.
I tend to go for the logical elimination route in these situations, applying a suitable lube to each component in turn, and then seeing if it makes a difference. This is how I managed to find a dry drop link balljoint that looked perfectly fine on the outside but, behind its rubber boot, was dryer than a Zulu's handbag. Squirting 3 - 1 from an aerosl can behind the boot immediately shut it up and, when it started making a noise again some 3 weeks later, I knew it was replacement time.
Of course, it could just be the brakes, in which case I'd be rather wary of my solution.
rob-81
Linegeist
rob-81
