Clutch drag?
Clutch drag?
Sorry, me again.
When I get to work after a nice motorway blat, I can almost guarantee that it'll crunch, even if I really ram the clutch pedal down. The rest of the time, absolutely fine. Any idea what's going wrong? No other gearchange issues.
scarecrow
Either
A, Clutch needs adjustment. (Refer to Haynes Manual) according to the manual you "may" need to do that every 6,000 miles. I tend to have that done by my local mechs when it goes in for its biannual wof.
B, The Gearbox oil neeeds changing or is the wrong viscosity. when was the last time you did this or have you ever changed that?
C, You just need to push your clutch pedal down because your leg has been relaxed after such a cruise on a open stretch of Motorway.
scarecrow
scarecrow
I would ask your mechanic to diagnose the problem - it's not something I think anyone can accurately diagnose via the forum.
I just got my manual from ebay for £2.74 including postage! There's plenty of others:
http://cgi.ebay.co.uk/Citroen-BX-Owners ... 4cedf97e8d
That paints a whole new pictureDollywobbler wrote:This is only affecting reverse through Scarecrow, which I guess doesn't have any synchromesh. Service was done by a specialist, so I reckon it's got the right grade in it. Clutch adjustment looks like the thing. How is this done? Must get around to buying a Haynes BOL...
Well if you get this sorted I have a similer problem in the TZS of not being able to engage reverse very easily. Since you dont use reverse not really been a bother for me.
macplaxton
I've had a Pug that had sometimes iffy gear selection (harder than it should be to put into gear) and it was supposedly adjusted by someone else. Anyway it was little better and eventually it went away.
Then the clutch died completely. Drove back from Newry without it.
What had been happening was the individual fingers in the centre of the clutch had been breaking their tips off one-by-one and this affected the release of it. When they'd all given up there was no release action.
Adjust the cable. If that doesn't cure it, or it comes back. It's time to do the clutch.
From experience, once you start having to adjust the clutch, it's a good sign that the clutch is on it's way out
Most times it's the thrust/release bearing that's seizing up under load and burning it's way through the clutch fingers.
The good news is, it'll be like driving a new car once it has a new clutch.
scarecrow
