XM/Xantia Doseur valve for a BX?
Muiruri
Post by Muiruri »
Hi,
Can an XM or Xantia doseur valve be fitted on a BX 19GTI? Mine is on its way out.
thanks
Sammy Muiruri
1988 BX 19 GTi
1976 GS club
Yep!
x 103
is the Xantia on one not different, by appearance at least?
BX Bandit
Backslash Bandit
My Cars: Cars
Post by BX Bandit »
A BX in Kenya?!
Muiruri
Post by Muiruri »
Several actually, I know of four. A number of Xantias, one XM, DSs and a grounded C something!
Sammy Muiruri
1988 BX 19 GTi
1976 GS club
Vanny wrote:is the Xantia on one not different, by appearance at least?
Yes, but it'll fit!
Phoenix has an XM unit, and the TD has a Xantia one.
IIRC all I had to do was undo a bolt that is actually a metering valve and move it to another port..
khan
Yahoo Messenger: khan_74_ro
Post by khan »
in fact the spring at the bottom end is different for the Xantia and XM, the spring is tougher than that on the BX doseur, but it's an easy swap, only the bottom end must be removed using a hidraulic press and a circlip pliers
BX 2.1 Turbo D12 coming soon
Turboalternator
Post by Turboalternator »
Hallo all!
Look, I know the following:
IMHO = In my humble opinion
BTW = By the way
BX = Big ecstasy
But what on earth is IIRC?
Regards,
19 TRS Estate
In the past: 2CV, Dyane 4, GSA
Be faithful to your BX and she'll be faithful back
If I Remember Correctly
Post by RxBX »
Turboalternator wrote:Hallo all!
BTW = By the way
BX = Big ecstasy
Regards,
Philip Chidlow wrote:If I Remember Correctly
To decipher anything else (if needed), can be found via THIS website (Hopefully) !
:D
JayW
x 13
Post by JayW »
So what's FTW?
For The Win :D
JayW
x 13
Post by JayW »
That's what i thought, but quite often that doesn't fit the context in use.
The alternative is "F*ck the world", but again, rarely fits :?
rayfenwick
Post by rayfenwick »
Farts That Whistle?
:roll:
Ray
www.citroencarclub.co.uk
