Pretty chuffed given looking from its passed Wofs an annual (every other wof) tradition of picking on a little drip or damp patch caused by the hydraulic system thats proved to be nothing.
Tyre wear is something I have been keenly watching since putting 4 new tyres on last May and July.
Rear Tyre Wear shows minimal wear (as expected) in 10,000kms @ 7mm
Front Tyre Wear in 11,000kms @5mm
The big test was the theory that Nitrogen reduces tyre wear? Well not that I can see in fact given that Firestone NZ over inflate tyres I think the reverse is true. The only benefit I noticed with removing oxygen from tyres is that the pressure loss over the distance and time was probably due to monthly pressure testing.
Anyways a good feeling when your car passes the tests
