"wrrrrrrrrrrrrrrrrrrrrrrrrrrRRRRRRRRRrooooom, wrrrrrrrrrrrrrrrrrrrrrrrrrrRRRRRRRRRrooooom"
...at constant speed on any sort of surface, no matter how smooth. It must be some sort of interference, maybe between engine noise and something else. During the vibration peak, the steering wheel and dashboard flex quite heavily. What I already know:
1) The wheels have been balanced by a professional with these tyres fitted.
2) I changed the break discs and pads and the problem was present before that - no difference - so I assume the discs are fitted properly. (Also there's no vibration from the brake pedal, indicating unbalanced discs).
I'd love to get rid of this problem. I *think* that the rear wheel bearings might be knackered, but I'm not sure how to check. But they really sound kinda "crunchy" when I turn the wheel with the rear on a carjack. Could this be the sole reason? Is it hard to change them? (I heard scare stories about special tools and some heating/cooling trick...)
I fear it's a combination of different small problems that accumulate to this interference pattern. Any more hints?
Thanks
PS: btw I alway love to repeat this: I'm astonished by the fact that the BX doesn't rattle at all. So many old cars sound like they're about to fall apart on the highway. Even though the Dash bounces quite strongly, there's no rattle from the vents, the seats or any other bits. I really like this
PPS: And who at citroen decided to use 5-edged nuts on the front calipers???
