heater motor
sub777w
heater motor
hi any body got a heater motor for sale cheers for my diesel bx
electrokid
Hi,
Your motor possibly needs new brushes - not available from Citroen or Valeo but the whole blower unit is still available but it's around the £200 mark.
That being a bit on the steep side the other alternative if no-one has a motor for you, is to make new brushes by filing / sanding down some larger brushes to the right size.
Brushes for high voltage equipment are a different composition to those for low voltage - low voltage brushes are 'harder' and have a much higher copper content - about the only starting point these days is to use brushes from battery power tools.
The Citroen brushes are 7.43mm x 5.91mm - I've recently bought some Makita 191971-3 (which is a pair of part no 6434308) which are 7.18mm x 6.85mm with the intention of modifying them to the Citroen dimensions but I haven't got around to it yet - I'll post the results when I do.
Cheers,
Brian.
Cheers,
Brian.
2002 C5 HDi SX estate
sdelasal
New item is £77 here - http://www.aepdirect.com/index.php?opti ... ct_id=1015
electrokid
sub777w
cheers for that,
electrokid wrote:Hi,
Cheers,
Brian.
sub777w
sdelasal wrote:New item is £77 here - http://www.aepdirect.com/index.php?opti ... ct_id=1015
Are you sure it is your motor? It often isn't the motor on the BX, have you tested the motor or checked you have a live feed at the motor end?
sub777w
Defender110 wrote:Are you sure it is your motor? It often isn't the motor on the BX, have you tested the motor or checked you have a live feed at the motor end?
[/quote]
yes got live feed if you tilt moter left or right it works off car it will be bushes or bearings in armiture im going to get new moter for £77 from asuppiyer in glasgow cheers for help.by the way this bx diesel has only got 50 000 miles on it d reg all 21 mots with it bort off ebay for £132 and £100 to get it to newcastle so i though i can treet it to a moter and 4spheres
[/quote]
lol, too right it deserves a little treat, Nice one!
BX596
sub777w
Defender110 wrote:
lol, too right it deserves a little treat, Nice one![/quote] by the way when i took box out there was no resistor card in housing im sure when i did my tzd and txd 3 years ago they were there sopose working on so many dif cars you forget .heres one for you hdi 110 bhp in bx my dream just need to work out how to fit low prussure pump in bx tank proply ,
