TZD slow to rise - likely cause?
KevR
My TZD estate's always been a bit slow to drag itself off the floor. I think maybe now it's getting even slower. By comparison my other TZD picks itself up in about 30 seconds even if it's been stood for months, and the last time I started the crashed/spares TRS/TZD after two years of inactivity, it rose up even quicker than that!
So what's likely to be the cause on the current TZD? Weak pump?
I've also got the feeling it's been getting a bit more wallowy than usual lately, but that might be imagination (or it might be rear arm bushes on the way out of course).
Having all those other cars , camper vans , tractors , motorbikes , hydraulic diggers , bycicles etc. sat on top of it in the garage won't help!
KevR
Maybe that's the trouble! Perhaps I should just carry a spare wheel, rather than a whole spare car...!
Linegeist
KevR
Jolly good - that's the easy bit!Linegeist wrote:
I'd say pump.
You know it is amazing what a bit of TLC will do for an older car.
Sometimes it can be something really easy like checking the LHM level or tightening/replacing a belt.
Then start looking at maybe replacing the LHM with Hydraflush for the recommended miles.
Or Regassing spheres before assuming its the pump at fault.
I'm with Kiwi on this, elimenate those points raised, that'll be far cheaper than a replacement pump which may not cure the problem either. I'm especially a fan of hydraflush
I'll be getting some for my tzd which refused to rise the last time the engine was fired up
KevR
Good point, especially about the hydroflush, I'm pretty good at keeping levels checked and belts tightened, not least bcause I'm a skinflint and that kind of thing doesn't cost anything. Spheres are all fairly recently changed so it's probably not that, although you never know.
Daftly, it's probably easier/cheaper for me to try another pump than it it is to go the hydroflush route, simply because I have the luxury of a spares car.
Equally (or probably even more) daftly, I have the proper Citroen tool for checking operational systen pressures, but it hadn't occurred to me 'til now to give it a try...
I thought that when spheres were low on pressure, they allow more lhm into them, hence overall system pressure needs to be a lot higher for the pump to do, that's why it may take longer for the car to rise? I could of course be talking total cobblers
I forgot to mention Height Correctors to look at
As for the spheres what Mulley said. Not sure why but it was one of the things that a Citron Specialist said to me to look at. So who am I to argue...note same specialist also does not think hydroflush is any good prefering the flush with clean LHM as part of the 5,000km service...no I did not miss out a zero thats what they like to do over here
Linegeist
I hate to say this, but flat spheres will have no effect on system pressure - once they're full of LHM the system pressure resumes settling itself at the pressure determined by the PRV. The only effect will be to remove the flexible element of the suspension system - the nitrogen gas capsule.
You could, in theory, blank off each of the sphere mounting orifices with plates, and the car would still pump up. You'd just have spectacularly firm suspension.
rayfenwick
- Yahoo Messenger: otis_wilbury_ii
..and pretend you have a BMW with really low-profile tyres onLinegeist wrote:You could, in theory, blank off each of the sphere mounting orifices with plates, and the car would still pump up. You'd just have spectacularly firm suspension.
Ray
www.citroencarclub.co.uk
