wanted tzd front fog lights
any body got aset of front fog lights for tzd bx new or good secondhand cheers 07966203584
- electrokid
They are still available from Citroen (Bollingmores) - I was quoted £93.95 EACH ! Unity said they could get the same thing next day for around £50 each. Haven't tried gsf - I ended up buying a pair of something similar from Halfords for £26 the pair and modifying the housings to fit - it's not a nice mod though - it means drilling the foglight surrounds for a 4 bolt fixing and fitting hank bushes into the plastic in order to get some kind of height adjustment - unless anyone has a better suggestion which is quite likely
2002 C5 HDi SX estate
i did buy the same lighst from halfords today but mite take them back i noticed you got a quote for £50 each who was that pleaseelectrokid wrote:They are still available from Citroen (Bollingmores) - I was quoted £93.95 EACH ! Unity said they could get the same thing next day for around £50 each. Haven't tried gsf - I ended up buying a pair of something similar from Halfords for £26 the pair and modifying the housings to fit - it's not a nice mod though - it means drilling the foglight surrounds for a 4 bolt fixing and fitting hank bushes into the plastic in order to get some kind of height adjustment - unless anyone has a better suggestion which is quite likely
- electrokid
Unity Motors - I think they only have a few branches around here in the south - you might get a similar price from gsf - and you'll get 10% off through BXclub (thanks guys) - print out your 2010 membership card from
http://www.bxclub.co.uk/forum/viewtopic.php?t=8296
gsf are at
http://www.gsfcarparts.com/
With the Halfords lights I drilled holes in the corners of the black surrounds and similar holes in the plastic pods on the BX. I squeezed hank bushes into the plastic and gave them extra strength with epoxy. I haven't set up the beams yet - I figure if it's difficult I'll put a spacer under the original holes to act as a fulchrum so they can 'rock' up and down a bit but tighten all the bolts in hopefully an ideal place. I used hank bushes rather than nuts because I figure it's difficult to stop them turning when tightening the screws at the front - not nice but hopefully it'll work.
gsf are at
thanks mate for your adviceelectrokid wrote:Unity Motors - I think they only have a few branches around here in the south - you might get a similar price from gsf - and you'll get 10% off through BXclub (thanks guys) - print out your 2010 membership card from
gsf are at
- electrokid
No probs
I omitted to say that I glued the lens / reflector assembly to the black surrounds using silicone rubber, and I ditched the plastic backs as well - sealed the bulb area with non-corrosive silicone rubber making it hard to replace but hopefully no longer subject to rusting.
got in contact with gsf got cibi fogs they are acarbon copy of the real thing and got discount with being in the tradeelectrokid wrote:No probs
- electrokid
