16 valve poor gear change
Alastair
Post by Alastair »
Hi..am looking to improve the gearchange on a recently acquired 16 valver...HAve identified loads of play in two parts...a rod which citroen suggest is part number 95495342 and a part which they describe as a control return part number 95569317...however the parts according to them are no longer available!! Any ideas anyone as to where they may be obtained or who may have old stock??
Thanks
Alastair
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
Mike E (uk)
Post by Mike E (uk) »
The gear change always is a long and vague on the BX.
The rods do appear on eBay from time to time.
Mike
Kevin B
Post by Kevin B »
Might similar parts (requiring some minor modification) still be available for Peugeot vehicles that use the same BE3 gearbox. I know that the peugeot 306 has very similar looking components in this respect, but the rods are a different length.
Matt H
Post by Matt H »
I seem to remember Luke on the 16v forum used modified 205 GTi linkages to achieve a shorter throw gearchange... it might be worth asking over there.
themildbunch
Re: 16 valve poor gear change
Post by themildbunch »
Alastair wrote:Hi..am looking to improve the gearchange on a recently acquired 16 valver...HAve identified loads of play in two parts...a rod which citroen suggest is part number 95495342 and a part which they describe as a control return part number 95569317...however the parts according to them are no longer available!!
hi - I had to rebuild the head on my 16v a few years ago and found one of the linkages was flopping about with hardly anything left in the plastic joint... As it was really easy to access with the head off I got one from Bryan Brothers in Bristol - no problem ordering then and I think they had to get it from France too...
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
