Low Miles Tidy BX 16TRS
NOW SOLD THANKS
ragger
Sounds interesting.
Where is the car, and how much are two key questions.
I have no experience of this variation, does it have PAS? Any chance of some pictures?
Other than a clutch cable replacement, are there any other likely issues to deal with before the testing time comes around?
Rob
Rob
Hi Rob
The car is in Ashby De La Zouch, and asides the clutch cable, which to be honest you may think is fine, it goes in all gears ok but the bite is a bit low. Yes it has power steering. It went through its last test with NO adviories and has done 300 miles since so should be fine. Its only done 7000 miles since the last cambelt change BUT that was some years ago so maybe it would be worth doing it again. It has new plugs, leads, coolant and air filter too.
Price well if it was a diesel with that mileage on it would be worth £800 but as its a 16 petrol then I know its not worth anywhere near. It can be bought without the tax if required.
The body is very solid but has the odd dent and the paint on the bonnet is a bit worn but polishes up well.
rayfenwick
Hi Tim
Brother is interested - can you PM/email me some photos?
Thanks
Thanks
Ray
www.citroencarclub.co.uk
