No Hazards
No Hazards
19TZI is out of MOT and the hazards are kaput, changed the switch and made no odds, could it be the relay? and where is it located Indicators work fine.
Thanks.
rayfenwick
Post by rayfenwick »
Sounds like the relay to me. Failing that, it's time to get the multimeter out :S
Ray
www.citroencarclub.co.uk
rayfenwick wrote:Sounds like the relay to me. Failing that, it's time to get the multimeter out :S
Thanks Ray, i dont have a multimeter or know how to turn one on though!
rayfenwick
Hmm. Electrics are the only thing I'm good at really on cars. Brother is useless, but good at the oily stuff, so we compliment each other quite well.
Ray
rayfenwick wrote:Hmm. Electrics are the only thing I'm good at really on cars. Brother is useless, but good at the oily stuff, so we compliment each other quite well.
Erm, well I can drive and im vey good at cleaning.....
rayfenwick
I noticed the cleaning - my car was so covered in flies etc that I daren't park anywhere near yours! :)
Ray
You can park next to mine at the next show if it makes you feel any better!
i think if it were the relay/flasher can the indicators would not work also,
years ago i fitted a brand new hazard flasher switch which turned out to be faulty, this was a MK2 BX
citronut wrote:i think if it were the relay/flasher can the indicators would not work also,
Yes I agree with Malcolm, try another switch that you know is working out of another one of your fleet :lol:
rayfenwick
Re: No Hazards
Roverman wrote:...changed the switch and made no odds
Unless Tim has 2 dead switches, the problem must be elsewhere, either the wiring or the relay...
Ray
I will give it a whirl, do the hazards and indicators not use seperate relays then?
nope, same relay...
Well, actually it's a flasher unit but....
docchevron wrote:nope, same relay...
Ok I will change both to be sure from one that works.
just change one thing at a time, then you know whicch item was faulty, if you turn an indicator on this will help you find the flasher can in the fuse box, if it aint the old style ally can as that would/should be obvious
Flasher unit/relay is the third from the right (big black one) in the bank of relays.
I too like Malcolm have bizzarly had faulty new hazard switches on more than one occasion (not Citroen) + failed ones out of second hand parts bins but for me whenever the Hazards have failed with indicators still working it has always been the Hazard switch. I can't think of any logical reason for this but it is strangely how it has been.
