16 valve cooling fan
Alastair
Post by Alastair »
My newly acquired 16 valve cooling fan is inoperative. I have checked all fuses....changed the fan switch for a new one. The fan itself works if i short out the terminal block which plugs onto the switch....Only one of the two speeds works I notice...is there a resistor or such like located somewhere???? Or does anyone else have any futher ideas?
Bx turbo diesel 1989
Bx 1.9 Rd estate 1989
Citroen Light 15 1952
Bx 17 TZD diesel turbo 1992
Xantia 1.8 16v
Mike E (uk)
Post by Mike E (uk) »
BX16V has low speed and high speed fan modes.
Which is missing?
If you short the connector to the thermal switch on the rad, you should be able to select between the slow and fast speeds.
If the slow speed does not work: the voltage dropper resistor is hidden on the front of the car behing the bumper, below the NS headlamp. This probably has corroded contacts or has got disconnected.
Mike
Discoil
Post by Discoil »
Just trying to understand this wiring dia in front of me and no. 813 is a cooling fan relay ( slow and fast speed )from fuses F1 ignition and F4 battery ..To water temp switch and then onto fan.
:? Actually working from a twin fan system as I haven't found the correct diagram
Land Rover Discovery TD5
Alastair
Post by Alastair »
Thanks...i knew there must be a resistor somewhere....i shall look today.
Xantia 1.8 16v
x 103
twin fan system uses a different arrangement to a single fan system, and both of these are different to the AC system. Only the single fan system has a pull down resistor i believe. The fan relays are usually in the scuttle above the battery.
