I checked it at least twice between buying it and taking it to the garage, and it was always on MAX (v rusty water!).
Mark.
Right I take your pointjeremy wrote:You're right - with a pressurised system the loss should be negligible but this depends on there being adequate room for expansion. Max marks are sometimes correct and sometimes not. If they're not then the surplus will be blown out of course.
The point I'm making is 'does it drop any further' - ie if left will it go below min?
I think you will find that the plastic moulding with the radiator cap on it is in fact a header tank - similar to the one I described for the ZX. This means that the level as shown under the cap is the level in the header rather than the level in the radiator core. It probably also means that the water has to syphon into the core or something when it is topped up and may really only settle when the engine has cooled and drawn water out of the header. If the level has dropped significantly this may not happen first time!
Yes the old stuff was quite rusty from what I saw on the coolant dipstick - it made it much easier to read the level! I'll try your cardboard trickken newbold wrote:I take it you've changed the coolant ? was the old stuff really rusty? if so after refilling with new antifreeze I've known water pumps start to leak.
Keep an eye out under the engine drivers side, try putting clean cardboard under there at night, watch for result.
