Green Y piece on top of LHM tank
Yup, it decided to break, i've used some glue to stick it back together as a temporary measure, but i'm sure it'll fall apart again. Does anyone have a spare laying about, quite happy to sort out postage etc... or can these still be purchased new? or has anyone created their own replacement? I think i remember seeing a picture of one where a couple of holes had been drilled in the top cap so that the clear thin pipes would fit into them.
Apologies for this post if it seems daft, i'm pretty sure that i've never seen any lhm actually going from these pipes into the y piece ever, but knowing my luck it'll piss out lhm at some point.
Linegeist
Post by Linegeist »
When my first one disintegrated Mulley, I used a windscreen washer 'Y' piece, and just warmed the pipes using a hot air gun until they slipped over it.
If you're really stuffed, PM me and I'll send you an original.
Re: Green Y piece on top of LHM tank
Post by RxBX »
MULLEY wrote:... or can these still be purchased new?
Hi Mulley,
I think that's yes according to THIS thread (part no 5270.14 ) also there some on E-BAY but its not Green (Orange and the part no is quoted as 5280.E2 ) but one would assume it probably will fit being fairly flexible when new but maybe best check the part number first with the main dealer before buying it !
:D
Cheers Richard, i searched but couldnt find that post, i thought i'd seen one :oops:
Erm, £5+, you've got to be kidding :x Theres no way i'm paying that, anybody got a good 2nd hand one that they don't want?
Bob, cheers, when i factor in the cost of buying a hot air gun, erm :wink: i think i may take you up on your kind offer, pm me how much you want & how to pay you if you're happy to do so :?: unless anyone else has got a spare that they deffo don't want/need. If anyone is going to a scrappies, could they salvage said part please?
sub777w
Y PIECE
Post by sub777w »
:D YES STILL CAN BUY THEM FROM CITRON IVE GOT 3 SPARE YOU CAN HAVE ONE GIVE ME YOUR ADRESS .
1993 1.7 tzd red
1986 1.9 dtr white
pm'd sub777w
If this fails there is always my parts car your hell bent on stopping me stripping? :lol: :lol:
Sub777w has kindly offered to send me one, so hopefully that's one job sorted :D
Sorry Kevan, i'll be sending over various parts to get your tgd turbo back on the road again :lol:
You're not in a rush to get that rear light are you? i'll be able to send it next week if that's ok?
1.5mm drill bit in a drill.
Drill two holes in the cap, insert pipes into freshly made holes.
Cost = nil.
Subway777w, please stop shouting, we are not deaf.
I'd need to buy a drill, so not quite as cheap as you think :wink:
here is trade price and part No.
0000527014 3 WAY UNION 4.43 GBP 5.21 GBP 5.21 GBP
or you can buy a widscreen washer plastic three way union from a factors, for a pound or two,
then add three short lengths of small bore rubber hydraulic tube, for each of the three plastic pipes to plug into
Linegeist
Post by Linegeist »
Yep. That's what I did. Cost 70c from the French version of Halfrauds. :wink:
sub777w
Post by sub777w »
docchevron wrote:1.5mm drill bit in a drill.
Cost = nil.
i now your not deaf my capslock was stuck fixed now.
1993 1.7 tzd red
1986 1.9 dtr white
The mind boggles!
Linegeist
Post by Linegeist »
sub777w wrote:i now your not deaf my capslock was stuck fixed now.
Cool! All we have to do now is introduce you to the "," key, the "." key the "shift" key and the concept of paragraphs. :wink:
