Source for brass drift/ punch
Aerodynamica
Post by Aerodynamica »
Needed to do the reseating job of the ball bearing check valve in the regulator.
I tried a tools place to no avail - is there a recommended chain store for an appropriate brass drift?
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
no idea TBH..
I have an old piece of brass bar I use, can't even remember where I got it from, but I've had it for years, which isn't at all useful I'm afraid..
prm
Post by prm »
Try RS Components, brass,SS,mild etc. They have a good size range of stock metals.
Or your local plumber for an old ball valve arm.
Nick the one from your loo, wife/girlfriend won't notice for a while :o :x
Regards.
Aerodynamica
Thanks guys - in the end I went to machine mart and picked up a whole punch/drift set including a series of brass items.
CX up on ramps, accumulator off, check valve retainer removed and punch set in ball bearing housing, one single hefty whack with a hammer to the brass drift to the ball and reassemble.
Regulator tick time has instantly gone from average 40 seconds to average 1'10" sec - massive change!
I think this procedure works.
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
