XM and XM2 piston seals
electrokid
Post by electrokid »
Hi Folks,
Amongst the spares received from Nick the other day I've found a couple of piston seals still in their packets - part number 5 462 418. I've identified these as 'rear brake disc caliper piston seal' for the XM and XMII but you should verify they are the correct types before fitting.
If anyone needs these PM me with your address and I'll pop them in the post.
2002 C5 HDi SX estate
these are the main presure seals, here is price and part No. from service citroen,
5462418 PISTON SEAL 7.49 GBP 8.80 GBP 8.80 GBP
electrokid
Thanks for the info Malcolm.
