MOT Day
MOT Day
Wish me luck, 19TZi is in for its first MOT under my ownership tomorrow, cant see anything obvious and at £54 it should blinking pass!
Only thing was the non working hazards which are now rectified thanks to a new fuse!
sub777w
Post by sub777w »
its only £25 in tyne side robbing b :twisted:
1993 1.7 tzd red
1986 1.9 dtr white
rayfenwick
Post by rayfenwick »
Good luck! Hopefully you won't need it. :)
Ray
www.citroencarclub.co.uk
im sure Tim you would have polished her so much the MOT tester will be blinded by the glaire, and wont be able to see any failure points,
dont you get a trade price for your MOT's
mountainmanUK
Post by mountainmanUK »
.....as long as the ashtray's empty she'll be just fine Tim! :)
Its a full retail price MOT today at work, they changed the rules so you get two free per year (instead of as many as you like half price) and then after that its retail money, which is fine if you have two cars, like me who has 7 it gets pricey but I cant be bothered to take it to a local MOT station for some grease moneky to suck through his teeth as soon as he seems the Citroen badge and fail it for having no hand brake effort (on the rear wheels!)
All was well until this morning on the way in when the engine "K" lamp AND the ABS lamp came on within 2 minutes, they are both off again and lets hope they stay that way, it hasnt moved for a while so hope its just a tantrum.
Its actually rather filthy at the moment though Dave after not being used for about 6 weeks.
Failed
Split steering rack gaiter and the ABS lamp came on whilst on the MOT ramp, its off again, will take the wheels off and give the sensors a good clean.
Not bad over all for a 20 year old car.
rayfenwick
Not bad at all. You'll soon have that sorted :)
Ray
rayfenwick wrote:Not bad at all. You'll soon have that sorted :)
Gaitor kit was on the shelf at the local motor factors for £6 the pair so should be done next week!
Roverman wrote: Gaitor kit was on the shelf at the local motor factors for £6 the pair so should be done next week!
Better than the GSF price of £13 for one side then! :D
Begs the question though.... plastic or rubber gaitors...
hope it was the O/S gaitor Tim, if it is the N/S just hope the gaitors you purchased are rubber as Doc says not thermoplastic,
to fit the N/S OE thermoplastic you have to dismantle the rack,
rayfenwick
citronut wrote:to fit the N/S OE thermoplastic you have to dismantle the rack
Urgh! :(
Ray
Thanksfully its offside yes! :D
rayfenwick
whew!
Ray
