Ebay stuff
Gibbo2286
Ebay stuff
Post by Gibbo2286 »
I promised I'd post this here before I stick it on Ebay, not BX except the seat belts but here it is:
Citroen Parts New Old Stock Job Lot.
This is a lot of Citroen parts for a variety of models, I’ve listed the ones I have been able to identify from the part numbers, there are a few parts thrown in that I’ve not been able to identify because they’re not wrapped or numbered.
There are a couple of Peugeot parts included.
6680.J5 Alarm module........ C3 - C5 - Berlingo
8978.FQ Seat belt electronic box..............Saxo
6560.T5 Radio harness..............Synergie - Dispatch 1 & 2
8265.G7 Fascia panel louvre LH..................C5
8264.L7 Fascia panel louvre RH Peugeot Boxer
8319.88 LH roof panel moulding,short, .......Relay
8351.C1 RH rear light moulding.........ZX Estate
4705.39 Handbrake trim set............Xsara Picasso
1323.07 Water pipe, tank to rad top......Xsara Picasso
9015.H7 Frame moulding inner LHR hinged door (2 of, one boxed one not) Xsara 5Dr + Estate
7908.A8 Rear bonnet seal...................Saxo
8546.J9 Door trim RHR hinged door C3 - C3II
8546.F6 Door trim RHR Sliding door.........Berlingo
3748.33 Hub plug..........Synergie - C8 - Dispatch
Unidentified items are:
Filler cap - screw on type
Plastic water outlet
Clutch pedal
Cam belt idler wheel
Rubber gasket possibly valve cover.
Wiring harness possibly ign switch & lights
An oval plastic trim
An injector nozzle replacement jet
This whole lot for £5.00 start price, no reserve post and packing to UK only £12.00 by courier.
Citroen BX RearSeat Belts
This is a set of seat belts removed from a 1992J BX turbo diesel
They’re in good condition, two side belts and the centre lap strap belt.
£5.00 start price, no reserve, £9.00 post and packing to UK main postcodes only.
Gibbo.
