white smoke
studleydave
white smoke
recently acquired bx16trs and still no use of it apart from driving it home. two or three days later after changing dist cap absolutely clouds of white smoke seen from exhaust for as long as i ran it and not smooth running either. is this likely to be head gasket problems.??
messerschmitt owner
could be too much oil and it burning in the cylinders
check if there are air bubbles fizzing through the coolant. If you have that and hard/pressurized water hoses, it is most likely to be a HG failure.
MY XM is currently getting a new HG at the moment - a snip at £1,040 inc. labour.
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
studleydave
white smoke
hi messersmitt man. thanks for reply. no bubbles in water but thought there may be seals on valve stems?
studleydave
white smoke
hi roverman. yep thats the one and yes only noticed after dist cap replacement, have checked correct leads to plugs. i do recall as i left that i had never had any luck with bx's, so that probably tempted fate.
- x 27
I reckon this thread and this one ( http://www.bxclub.co.uk/forum/viewtopic.php?t=12303 ) should be combined.
Gibbo2286
In that thread you've linked to Phil one of the posts says "Still got to find number 1 cylinder and hope it's on compression" or words to that effect.
I've got a tool in my box that I've had for over fifty years, a whistle that you put in the spark plug hole, it whistles when the pistons coming up to tdc on the compression stroke. Gibbo.
love it, want 1Gibbo2286 wrote:In that thread you've linked to Phil one of the posts says "Still got to find number 1 cylinder and hope it's on compression" or words to that effect.
Gibbo2286
