mat_fenwick wrote:How did you get the OS exhaust manifold round the steering column? I've build a manifold with 2 pipes above and 2 below, but I've had to modify the upper wishbone slightly...
If you answer my question then I may *think* about answering yours...
IIRC, I fabricated a 3-piece articulated steering column that went
around the engine - in any case, the front axle had to be moved forward by about 2" (from memory) to clear the sump pan, so the rack went with it. Once it was decided the steering column had to be lengthened, it was a small step to introducing another UJ and rotating the rack axially to give a different approach for the input shaft.
The hardest part was getting the front wheel arches to look right afterwards - finally achieved by simply cutting out the entire arch and welding it back on 2" further forward, then welding the cut-out section into the gap at the rear. This was before MIG, so it was a No1 Oxy/A nozzle, a handful of 1/16" rods, and lots of careful stitch-welding and panelbeating.
It didn't quite all match up as planned, but the magic of Isopon did its stuff and no-one was the wiser...........
citronut wrote:it should just drop straight in Bob, all the moutting points are the same, and you can put you welder away, diferent down pipe, most of the rest is much the same,
Thanks for that Malcolm - I'd hoped that was the case, but my Colonel once described me as "A lightning rod, through whom many unpleasant things choose to discharge"
In other words, if it's going to FUBAR, it'll FUBAR on MY watch!
Knowing my luck, I'll have the only Athena, from a one-week special production run, where the engine mountings are reversed just because it was Bastille Day ..........
