windows
jacksun1987
windows
Post by jacksun1987 »
Im having problems with my electric windows.
I trun the key and they not work. I unturn it then back on agine and it works.
Its been doing it quite a bit now.
Started happerning a month ago. I was driving wanted to put my windows up. Pulled over nothing happern. Then swich it on and off worked fine. Though nothing of it.
I havern tried the back ones when they go. But the frount and sunroof. Keep messing about.
THANKS
PAUL JACKSON
cosa 1.2 brezze 150 k had
x 103
Are you saying the sunroof and the windows fail at the same time? Does anything else fail? Can you check the rear windows next time the fault occurs?
If it was just the front windows, i would suggest the relay, but if other things are failing at the same time then i suggests probably a problem with the ignition barrel.
rayfenwick
Post by rayfenwick »
Having recently cured a faulty ignition barrel, that would be my diagnosis from what you've said.
Ray
www.citroencarclub.co.uk
richardd1652
Post by richardd1652 »
I had the same trouble with a Saxo.The heater blower wouldnt work and it turned out to be the ignition barrel.
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
jacksun1987
No they dont go up and down on the swich. I have to restart the ignetion. I dosent happern all the time. But just latley its been doing a bit more.
PAUL JACKSON
jacksun1987
It did it againe today.
I was in the car park put the windows down. Got back home then i tryed to put them up. The sunroof 2 frount windows didnt work. I should have tryed the back ones. But forgot. So i truned the ignition off and on. Then they was ok.
PAUL JACKSON
prm
Post by prm »
Try removing just the front door switches, disconnect the multi-pin blocks and check the operation on the rear windows and sun roof. Would go for the driver’s door first.
Could be the contacts on the driver’s switch locking in, causing the main thermal safety relay to remain tripped.
Possible ?? fault/connection problem on the main control box.
Regards
jacksun1987
Thanks
I do know the one touch button is a bit stuck in. I dont use it becase if i do somtimes. It goes down by its self.
Could that be another reason.
Thanks
PAUL JACKSON
prm
Post by prm »
I should imagine that’s the cause, with the auto fully up-down buttons on the driver’s side locked in, but don’t rule out the main control box
What gave me a slight pointer is the windows would operate with an off-on ignition, where the thermal relay would possibly reset on a once only basis,
Don’t check the auto close safety thermal/pressure stop with your hand or head. They bloody hurt. :oops:
The safety pressure is not as sensitive as modern units.
Regards
jacksun1987
Thanks.
See what happerns
PAUL JACKSON
jacksun1987
Any one a the citroen car club wanna look at it for some money.
PAUL JACKSON
jacksun1987
Its not just the windows what pack up. Its also the electric mirror as well. It like all the electrics pack up. The louxury iterms lol. Windows mirrors emmmm surley theres somemore. But the ones for driving the car. Like the indercaters lights dont. They seeem to be ok.
PAUL JACKSON
rayfenwick
Ignition barrel..... but I said this before.
My car had *exactly* the same symptoms until I replaced the return spring.
It could also be the connection where the 2 plugs on the end of the barrel join the loom under the dash, but they seemed pretty reliable looking from what I remember.
Ray
jacksun1987
Ill see what happerns thanks. It is slowley geting worst but last night had no problem with it. Mabye i just have to turne the key slightley harder or turn it over a bit more when starting. Somthing silly like that.
PAUL JACKSON
rayfenwick
The problem is quite likely the opposite - that after turning to the start position to start the engine it isn't returning exactly to the "everything on and engine running" position. Try encouraging it a little, and see if that makes a difference.
Ray
