Wanted: engine Breather assembly for 1.9D
sdelasal
Post by sdelasal »
Does anyone have the breather valve into the intake manifold, the pipes into the rocker cover and block and even the filler tube. I suspect mine, at least one pipe is tapped up to repair it and if I can find a good set of spares i'll simply replace it. Steve
here is price and part No.'s of the filler neck and tube going to the crank case,
for a 1.9 petrol carb,
there is a diferent part No. for inj modles,
if they are still availible
0000118025 OIL VAPOR HOSE 19.23 GBP 22.60 GBP 22.60 GBP
0000117824 OIL BREATHER 16.82 GBP 19.76 GBP 19.76 GBP
sdelasal
Post by sdelasal »
I should have been more specific - mine is a diesel. I'm pretty sure it's the valve that plugs into the air intake manifold on top of the engine that is the problem. Anyone know how they should be tested? I can put a small positive or small vacuum at either end and it just blows thru. If I pull a bigger vacuum and put my finger in the other end, it hold the vacuum. I would expect it to only flow when i put a vacuum on the air box end. steve
sorry i missed the D in the title,
here is 2 part No.'s dependant on your RP No. for the filler neck,
1180 37
OIL VAP STRAINR
- UNTIL RPO No. 05074
1180 95
SINCE RPO No. 05075
here is price and part and part No.'s for the above,
0000118095 OIL VAP STRAINR 24.03 GBP 28.24 GBP 28.24 GBP
0000118037 OIL VAP STRAINR 18.75 GBP 22.03 GBP 22.03 GBP
Gibbo2286
Post by Gibbo2286 »
What our friend is looking for Citronut is the regulator part number 0361.58. Gibbo
i could not see that part listed on service citroen under BX, but can see it for a ZX, there were two or three diferent type's,
also sdelasal did ask regarding the other parts
i tried that part No.,
and it came up with Synergie,ZX,C15,XSARA and XM MK2, but no BX even though it will probably be the right part,
0000036158 REGULATOR 26.79 GBP 31.48 GBP 31.48 GBP
you could try that part No. at your local motor factors as they might b
e able to match it up
Gibbo2286
Post by Gibbo2286 »
It's in the BX section on my catalogue Malcom but to be sure I dug out the invoice for one I bought from Citroen myself last July. Gibbo.
Gibbo wrote
"It's in the BX section on my catalogue Malcom"
thats most odd as i enterd that part No. into the search box on service citroen,
and it came up with family's as in my last reply above,
