One for Malcom, Citronut
I've got an engine harness, new in the Citroen pack, that I've been trying to identify with a part number that doesn't come up on my catalogue search, maybe you could try in yours. Part number 6529.YV Gibbo.
sorry Gibbo
it comes up as no documents found on service citroen,
you could ask your local citroen dealer to enter into there system to see what if anything come up
- electrokid
Doesn't get any results on Google either.
You could take some pics particularly of the tail connections and post it to see if anyone recognises.
You could take it to the National to see if anyone recognises it.
You could note the layout and compare it with CCT diagrams.
Or you could get some Spitfire in and forget about engine harnesses for a while
2002 C5 HDi SX estate
Thanks chaps, I thought that might be the answer, my local Citroen parts man it will have to be.
This is a quite long harness with a box attached with a couple of relays in it, doesn't look like anything pictured in the EP catalogue, it's the only piece out of over a hundred in a job lot that I haven't been able to identify. Gibbo.
- rayfenwick
As you said, cablaggio essato IS Italian for exact wiring.
If the lid will open on that black box without doing any damage, the innards may give a big clue as to what it is....
Ray
www.citroencarclub.co.uk
- electrokid
- electrokid
Unless the chip inside is a PIC in which case we can definitely say it's a widget.the innards may give a big clue as to what it is
Trying Shepherd Neames 'Early Bird' this evening - quite hoppy - quite bitter - quite nice
Ok - the clues I've picked up on so far - I would guess the 2 grey connectors are outputs and fairly close together. The tab with the hole looks like a 0v / ground and the connector next to it may be power - the connector below that has 3 wires so possibly off to a sensor. The box looks as though it simply clips into place so probably not mounted on the engine itself - almost certainly nowhere hot.
The 3 wire connector could be CANBUS in which case the box could be doing anything.
- electrokid
Ok that's a better pic - Tab probably ground, one next to it probably power and the 3 wire is control for 2 relays. So power control with 2 outputs - fairly beefy looking connectors / wiring. It's a 'general purpose' box - there's space for a third relay - could be control for an add-on on option. And it bolts on - now we can see the screw holes.
