I'm breaking my crashed estate and I was thinking of simply unbolting the front subframe, disconnecting the struts, (plus all cables, exhaust etc), then simply lifting the body up and leaving the whole front assembly in one lump 'til later.
Any reason why I shouldn't...?
Engine/box/subframe removal
KevR
well the engine is not attached to the sub frame appart from by the lower stabaliser bush, as the engine and box mounts are hanging from the inner wings,
that is unless its an early 1.4 powerd unit which sitts on the sub frame,
KevR
Ah, ok... so all in all a pretty stupid idea then!
I'll just hoik it out the top with the JCB then.
assembled
- My Cars: 1991 Citroen BX TZD TURBO 4WD*
*aspirational - x 2
Re: Engine/box/subframe removal
I am considering to do the same as my two donors sits outside and I have no easy way o lifting the engine out.
Much like doing this:
You can see that engine/transmission/subrame, front struts are all assembled prior going under the body.
I suppose I need to disconnect gear linkage (visible int the photo above), cooling system, hydraulic pipes to front struts, steering wheel, brake valve from inside (and leave hanging on pipes with sub-frame) electrics. What else should I consider? My idea is to support engine/sub-frame on the ground, undo engine mounts, sub-frame bolts and then lift the body upwards. Then the body goes away and I am left with all the goodies
Opinions of more experienced would be very appreciated. Especially of any pitfalls waiting for me.
P.S. happy New Year everyone
1992 TZD Turbo berline, aircon, ABS
1991 TZD Turbo berline
1989 GTi 4x4 berline, ABS
Never done it this way, but it doesn't sound a daft idea. Avoids any messing with the front suspension apart from the strut tops, and no need to tilt the engine to remove.
themildbunch
When Doc helped me swap my engine out he took the gearbox out first - it made the engine an easy straight lift out then, no tilting required... watch the height corrector though, very easy to damage...
I was amazed how light the manual box is - I could hold it from above quite easily..
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
if/when i need to take engine and box out of a BX, i always drop it out below, and yes this can be done with the front sub frame still in place,
assembled
*aspirational - x 2
Thank you. I am aware of that, but what really interests me is whether removing engine together with sub-frame actually has any benefits. The car is in ground, unmovable and any work from underside not very pleasant.citronut wrote:if/when i need to take engine and box out of a BX, i always drop it out below, and yes this can be done with the front sub frame still in place,
I am thinking of putting a Euro pallet under everything, unbolt sub-frame, struts, engine mounts, cables, hoses and just raise the body. My goal is to remove all good stuff from the body and get rid of it.
there's no reason why you could not do this, even though the only connection between the engine/box and the sub frame is the drive shafts,assembled wrote:Thank you. I am aware of that, but what really interests me is whether removing engine together with sub-frame actually has any benefits. The car is in ground, unmovable and any work from underside not very pleasant.citronut wrote:if/when i need to take engine and box out of a BX, i always drop it out below, and yes this can be done with the front sub frame still in place,
KevR
Rather belatedly...
I've done this a couple of times - either cutting the subframe in front of the rear mountings (when the frame was rusted out) or just unbolting it properly, then pulling the shell off over the top. Works a treat but as Malcolm says, the engine's only held to the subframe by the driveshafts so it's worth loosening the shaft nuts and the lower ball joints before you start (more difficult later) so that once you've got the shell out of the way it's easy to split the rest down into its component parts.
Wouldn't bother leaving the struts in place as they're so easy to disconnect from the hubs and will only get in the way as you lift the shell.
