my mk1 diesel has bad water leak!
ren16tx
This weeks BX legend
Post by ren16tx »
Sophie my mk1 italian bx 19trd showed her age the other day, and couldn't hold her water any longer!!! bless her! :roll: happened on the A3 just outside Guilford! and had to be relayed home!!!
i know the radiator is on its way out,and keep a close eye on that,however,she's blown a pipe or something from behind the engine?? you pour water into the rad, and pours straight out from behind the engine!! so in effect, is not drivable, luckily, the headgasket is ok!
im no machanic! so any ideas/suggestions/help would be great!
chris
GSA X1,GSA estate, GSA PALLAS C-matic,Simca 1100,Renault 16TX auto, yellow Visa super E, wanted mk1 bx!
Aerodynamica
Post by Aerodynamica »
Crusty old water hose split?
Graeme M
CX 2400 Pallas LPG
2CV6 dolly (SORNed)
Mk1 Xantia 1.9TD SX
'c'est hydropneumatique'
Post by ken newbold »
Aerodynamica wrote:Crusty old water hose split?
for sure, but which one :?:
There are several candidates.
The heater pipes that go through the bulkhead would be favourite. Not too easy to get at, but there are worse ones behind there. So we won't talk about them yet :)
it could also be the water branch at the rear of the engine, or one of the rubber blanking cap's fitted to the water branch
ren16tx
Post by ren16tx »
i've had a good look today, and what a sod!! it appears to be a split hose,the hose comes from the bulk head and at the other end,where it sleeves over a metal pipe, is split there, i've tried to "blank" the hose off, with no effect to water losage!! this the heater hose??
is this a driveshaft out job??is it a garage job??
ren16tx
Post by ren16tx »
and does anyone have "this" hose?? or are they easily available?
Yes it's one of the heater hoses :(
You're right, not a good job but is do-able, just awkward.
No idea if the hose is available now or not. The main thing to be careful of, is not to break the plastic pipes that go through the bulkhead then you will have a bad job on your hands.
Just take your time and be patient. Access may be improved by jacking up the engine, then remove the top engine mount and pull the engine forward, wedge a suitable piece of wood between the engine and bulkhead to help you. :)
ren16tx
Post by ren16tx »
garage job then!!!!!!!!! :roll:
richardd1652
Post by richardd1652 »
Go on Chris ,take the bull by its horns and you could show everyone the scars at the National?
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
Chris if you forward your VIN No. i will put it into service citroen, even if just to get part No.'s
ren16tx
Post by ren16tx »
richardd1652 wrote:Go on Chris ,take the bull by its horns and you could show everyone the scars at the National?
Richard.
garage then!!
ren16tx
Post by ren16tx »
citronut wrote:Chris if you forward your VIN No. i will put it into service Citroën, even if just to get part No.'s
PM sent!
Richard.
garage then!!
It's OK, they'll probably charge you more than the car's worth and manage to break something else in the process, then tell you it was broken already :evil:
or am I being cynical :?
ren16tx
Post by ren16tx »
BX CHALLENGE in Aldershot this week!!! FREE COFFEE/TEA!! :lol: :P
richardd1652
Is she fixed yet Chris?
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
