Passed it's test
Discoil
Passed it's test
Post by Discoil »
Took it in for testing last week and it failed.
So I said to garage owner ,
a) You mend it
b) I mend it on your premises
Result was I went back after lunch and mended it myself on their wheelfree ramp (2 post ):D :D
Cv boot to offside outer
Replace ns top suspension mount
Wiper blade to front
Adjust os headlamp
And then took it for some welding
Land Rover Discovery TD5
I'm a bit confused by the "Replace ns top suspension mount" is that the part where the sphere is attached or did you mean the engine mount?
Discoil
Post by Discoil »
It's the rubber bonded mounting between the upright strut and the body/ wheelarch
Oscar
Post by Oscar »
Crikey, never heard of anyone replacing that. Your MoT tester must be keen.
I take mine to the guy who does all the cars from the local independent Cit garage (medway citroen). He knows Cits and won't fail them for having oil in the suspension or something equally stupid. Didn't AlanS once say his car had failed because the headlights were "pointing too high" when actually the rear suspension had lowered?
Anyway, congrats on the pass and on doing the work. Well done.
Gibbo2286
Post by Gibbo2286 »
The MOT tester has probably been told about those top mounts, some of them failed on the Xantias and there was a warning put out. Gibbo.
That's bizarre as they don't fail, unlike xm one's when they get rusty around that area. Personally i think the easiest solution is to remove any old rubber as it can trap moisture, de-rust the area & then paint it, surely an mot tester couldn't have any arguments about that as there is no corrosion on view?
