Hi all.
I have a disintegrating oil cooler hose on the new lump. I can't find a replacement but have a Xantia equivalent which is almost the right shape but not long enough. Is it possible to lengthen it by cutting it in half and jubilee-clipping each half to a length of copper pipe? Is anything terrible going to happen, like the copper melting the hose under heat and dumping all the water or something?
O
Anyone tried splicing hoses before?
Oscar
Re: Anyone tried splicing hoses before?
Hi buddy,
i am no expert but it seems like it would work ok till you find the correct pipe.
Obviously, the copper pipe would have to be of similar size but cant see a problem as long as the clips seal tight. Its the sort of experiment that would have to be done in an emergency to get you home and i reccon it would too.
Oscar
Stinkwheel
You will be fine on this Oscar.
I had an old V8 oldsmobile that i fitted a totally un-related oil cooler to. Your described method is exactly how i did it.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
stuart_hedges
I bought my BX with a copper-pipe bodge in the cooling system, and it\'s still there two years on! It\'s starting to go a little green so I intend to sort it properly soon.
The chap who did mine drew marks on the copper pipe in marker pen so that he could see if it started to push itself out of the rubber hoses.
A few years ago now, whilst on the way to Cornwall from Sussex i had a rather nasty leak from the suspension system at about 5pm on a Friday. Absolute sods law at on that day at that time.
Anyway, the long and the short of it was i found a Citroen specialist near Langport who did a 'bodge' using brake pipes, brazing and rubber tubing which cured the problem and was still working 5 years later. But for him i would not have made the fishing trip albeit a little later than planned.
What makes me remember it so well was the fact that none of us smoked, he had no matches and we had to resort to using a grinding stone on a drill to produce enough sparks to light a piece of paper to get his gas welder going to braze the pipes together. He wouldnt accept anything for it either as he was so into BXs. A memorable trip just for that. Caught and released a 100lb Blue shark too next day.
So, such repairs can and do work and well too.
Grenman wrote: Caught and released a 100lb Blue shark too next day.
Star man for releasing it,
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Oscar
