Clips for genuine Citroen workshop toolboards
KevR
Anyone know where I can get some? I've got several red/white painted steel toolboards which are marked for all the special tools (which I haven't got, mostly), some for BX, some for Visa/AX/CX etc. But I haven't got any of the special clips which fit into the small square mounting holes. Would like to put what tools I have got up on the wall, even if they don't match the original outlines, but need some of these clips or a suitable replacement - not even sure what the clips themselves look like. Anyone know...?
KevR
Not sure - I would have thought they'd need to hook over the board rather than just push in with a spring effect - otherwise the weight of the tools would probably pull the clip out. Maybe I should go to the main dealer to sneak a look in the workshop!
prm
Have a look at this site. They supply a fair range of combinations.
http://www.storagesupermarket.net/produ ... ps---pk-10
Fitted several of their boards for workshop tool stores. Just need to ensure the lower jam/locking screw is tight to avoid the clips coming away while removing the tool.
I can remember these boards, but not sure if the holes were round or square?
Regards
Regards
KevR
Thanks for that - I'll have a look. Holes in the Citroen boards are square.
scarecrow
KevR
scarecrow wrote:I can see a Frenchman with a marteau and some round pegs...KevR wrote:Thanks for that - I'll have a look. Holes in the Citroën boards are square.
