lhm level
lhm level
Hi all newbie with valver what should the level be in the sight glass handbook says yellow disc should be between two red marks overfilled mine y-day lhm pouring out of main tank!! syringed excess out and now all ok noticed a small clear plastic pipe running towards sphere on o/s is this overflow pipe doesnt seem to connect to anything! cheers mark.
scarecrow
JayW
- x 13
TBH, i've always lowered the suspension fully then fill the tank up to the top rib of the tank. It's not going to overflow and will give you some in reserve if you have any leaks....
Same goes for the engine oil really, always keep it just slightly overfull, especially if you're intending ragging it as deserves...
Needs to be on high to be have the correct level filled, if its in low then there will be potentially too much & it'll probably piss out from somewhere, doesnt cause any harm, just wastes money though....
doh!!
What stupid bit of advice that is.JayW wrote:TBH, i've always lowered the suspension fully then fill the tank up to the top rib of the tank. It's not going to overflow and will give you some in reserve if you have any leaks....
The only thing thats kept to the full mark is the Fuel Tank.
Overfilling anything is not done for a reason, if you want to ignore that then you wont have the vehicle for a long time.
If you have a valver without a baffled sump slightly over filling the sump is preferable to oil surge on corners.
That endures you wont have the car a long time, or at least a very often empty wallet.
JayW
- x 13
Erm, ever owned a Valver?kiwi wrote:What stupid bit of advice that is.JayW wrote:TBH, i've always lowered the suspension fully then fill the tank up to the top rib of the tank. It's not going to overflow and will give you some in reserve if you have any leaks....
Well that was not posted in your reply.JayW wrote:Erm, ever owned a Valver?kiwi wrote:What stupid bit of advice that is.JayW wrote:TBH, i've always lowered the suspension fully then fill the tank up to the top rib of the tank. It's not going to overflow and will give you some in reserve if you have any leaks....
My referance refered to mechanically sound vehicles
scarecrow
I've often wondered about how critical over filling the lhm reserve is... after all the reserve itself isn't pressurized so over filling shouldn't cause anything to blow. Having said that, why would Citroen include the level indicator if the level wasn't important?
Oil level can be critical, very. I once took the works van on holiday (one of those big Citroen jobbies) and the oil level light came on somewhere in the New Forest so I dutifully bought some oil and started topping up until I realised that the level indicator was faulty. Started the van and a couple of hundred yards down the road the engine started revving uncontrollably and I couldn't turn it off using the ignition switch, so me and my mate jumped out sharpish and waited until the engine made a large bang and backfired an oil slick out of the exhaust and all over a shiny new car!
The RAC man explained that the engine was running on the lubricant rather than the diesel.
The van drove fine after he drained the excess oil out.
JayW
- x 13
I suppose everything HAS to have a "Fill" level. It's not always relevent. I Mean, fuel gauges will read FULL but you can still get another 2 gallons in them... Doesn't stop people brimming their tanks!scarecrow wrote:I've often wondered about how critical over filling the lhm reserve is... after all the reserve itself isn't pressurized so over filling shouldn't cause anything to blow. Having said that, why would Citroën include the level indicator if the level wasn't important?
It's like many things, manufacturers may say one thing but when a car's 20 odd years old you tend to get a bit more used to their foibles than the manufacturers ever did...
Hence, after owning several Valvers over numerous years, experience (and general owners concensus) is that if you don't have a baffled sump (which very few are lucky enough to) then as an absolute minimum your oil level should be kept at the MAX level on the dipstick and if you're intending hooning it about properly then being a bit over can only help against oil surge.
As for other engines, feck knows, follow the manufactures guidelines (unless you've learnt better).
The original topic was about a Valver he's just bought, hence me replying with my experience of owning one.kiwi wrote:Well that was not posted in your reply.JayW wrote:
Gibbo2286
This is true, but since 3 of the press valvers suffered oil surge when less than 6 months old, and having seen first hand how easy it is to achieve oil surge in a D6C / DFW then a litre over the full mark is a good idea, it causes no harm since the level is still lower than the crank and therefore causes no crank drag and gives you a substantially reduced risk of wrecking the engine inside 2 seconds.
The original design was flawed, hence, either you fit a baffled sump, overfill it by a litre, or prepare yourself for regular engine rebuilds if you like riving the car hard, and it's pointless having a valver and driving it like a NA diesel.
Do i need to overfill on my txd
