extra radiator fan
bill o
extra radiator fan
Post by bill o »
I would like to instal twin fans to my 1.9 diesel,I have the fans which i salvaged from my old tzd,and would appreciate any advice on wiring them in,i am planning to tow my caravan to scotland so this is why i could do with the additional cooling.l
electrokid
Post by electrokid »
Me too :-)
I plan to do something fancy - but the easiest way is to buy a 2 pole switch to replace the single pole one that is already at the bottom of the rad - I've seen them on eBay - in fact I have one on my 'watching' list at the mo -
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... K:MEWAX:IT
2002 C5 HDi SX estate
prm
Post by prm »
If you can understand my hieroglyphics
Drawing of twin fans using relays that may help.
Relays can be mounted on the vertical section of the o/s inner wing, just forward of the LHM tank to avoid long cable runs.
http://i295.photobucket.com/albums/mm15 ... fans_1.jpg
http://i295.photobucket.com/albums/mm15 ... ods1_1.jpg
You could also include a fan run-on system with a fused direct feed from the battery by splicing into existing fan/s supply from R1. Then connected to new relay terminal 4, also linked into ter.1 ---coil +.
Fused battery + supply, into terminal 3. ....Terminal 5, no connection.
Terminal 2, negative/earth return.
Rather than connecting the + supply onto the battery clamp, you may find a spare spade connector on the main + supply terminal block, forward from the battery.
Relay coil should energise with ignition on. Then provide a direct feed from battery for fan/s run-on with ignition off.
There’s a section on the main drawing mod. Just install an additional std. BX relay on the bulkhead.
Regards
