Hi All,
This Bx I have recently bought has some rumbling noise coming from the front, I think it is the wheel bearings, I think they are becoming a bit dry, is it an easy job to re-grease the bearings or is it advisable to replace the bearings ? There isn't any play in the bearings, they are still tight, and they don't seem to make any more noise than usual when going around corners.
Cheers billvin
front wheel bearings BX TZD
billvin
JayW
- x 13
billvin
front wheel bearing
Hi JayW,
I've just been out and got the front wheel bearing, is it difficult to remove the bearing if you don't have an extraction tool as described in the haynes manual?
Kev
Kev
JayW
- x 13
KevR
Ideally, yes, but if you haven't got one it's possible to do them using a combination of cunning, brute force and large hammers...JayW wrote:You'll need a press.
JayW
- x 13
That is true. But, for the sake of sanity, bruised hands, pride, torn out hair and giving up halfway through...KevR wrote:Ideally, yes, but if you haven't got one it's possible to do them using a combination of cunning, brute force and large hammers...JayW wrote:You'll need a press.
KevR
I quite agree, but worth knowing if you need to do one on a sunday evening!JayW wrote:That is true. But, for the sake of sanity, bruised hands, pride, torn out hair and giving up halfway through...KevR wrote:Ideally, yes, but if you haven't got one it's possible to do them using a combination of cunning, brute force and large hammers...JayW wrote:You'll need a press.
