Hello fellow BXers.
I am in urgent need of the main ABS wiring loom, for a BX turbo diesel estate that I am working on returning to the road, (this was the BX estate with air conditioning advertised in Newbury a while back). I would even settle for just one of the ABS plugs (on the loom side) and a length of the coaxial wiring. So that I can repair the one I have, as it has a break in the main wiring loom inside the plug which connects to the NSF sensor, and it looks like getting to the wiring break will destroy the plastic moulded plug in the process.
Any help is very much appreciated.
Thanks in anticipation,
Kevin.
ABS wiring loom required......
Kevin B
How urgent is urgent mate?
I could extract an entire loom from a scrapper valver, BUT, there's another car sat on top of it, and several more between me and it.
It could take me a while to actually get at the car..
Kevin B
Hello Chris,
I still have numerous other items to attend to on this vehicle in the mean time, such as welding in some new metal in the NSR sill, and some hydraulic pipe replacement.
So being realistic I reckon a month from now would be about right.
Alternatively do you know any other Citroen cars that would use the same style of plug and socket arrangements for the ABS wiring.
Thanks for your help.
Kevin.
Kevin.
Dont know of anything similar TBH, but I'm sure it's a standard enough setup..
Should be able to get to the car inside a month, if so I'll remove the whole loom and post it to you.
Unless you're going to Startford, in which case I'll try and get it our before then..
JayW
- x 13
JayW
- x 13
Kevin B
Thanks Chris for your help, let me know how much cash I owe you, and send you a cheque.Dont know of anything similar TBH, but I'm sure it's a standard enough setup..
Out of interest, would a Citroen XM have a similar plug and socket arrangement?
I imagine the XM has similar, like I said, it's a pretty standard system..
That said I'll rip the complete harness out and post it on, no money required dude, it's not like I need it..
Kevin B wrote:Thanks Chris for your help, let me know how much cash I owe you, and send you a cheque.Dont know of anything similar TBH, but I'm sure it's a standard enough setup..
Out of interest, would a Citroën XM have a similar plug and socket arrangement?
Hi Kevin/Chris,docchevron wrote: I imagine the XM has similar, like I said, it's a pretty standard system......
The plug/socket used on XM's ABS systems are completely different, they are also two different types Teve's (Blue in colour) and Bendix (Green in colour) also the plug/sockets are different between them too which make them incompatible between the two system types as used on the XM's .
The BX ABS system uses a co-axial type of wire with a round plug/socket (the XM wires are just a two core type encapsulated within the silicone rubber outer shield) and plugs are are oblong in shape rather than round too !
Possibly an early Pug fitted with ABS (i.e. 205/309/405) could have used the same plug/socket as the BX ABS system
electrokid
I should be able to help you out with screened cable if what I have is the right stuff - 'RG59' with a single solid inner core - just PM me with your address and the length you need.
2002 C5 HDi SX estate
- x 116
