fuel filter ph1 valver
- x 25
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
As phil says, its under the boot floor. Stick your head under (support the car
) and its next to the spare tyre, above the fuel pump, on the opposite side to the exhaust. It is easier with the spare out, unless your on the back of a flat bed, with collapsed suspension, in chich case its near enough impossible regardless.
themildbunch
Um.. and be really careful when you remove the fuel pipes..
Apart from loosing fuel they'll be tight. When I did the fuel filter on my ph1 I tugged on these too hard and split the fuel damper which had got rusty over the years.. these are in a really tricky place to change too!
You can get special fuel line pliers to help remove them.. probably worth getting..
1988 BX 19 Gti 16v
1991 BX 17 TZD Estate
