Rubber rubbish
x 117
Rubber rubbish
The TD estate is up for its MOT. Checked underneath yesterday - ugh -
Both of the front hub bottom swivel joint rubber shrouds had just disintegrated.
They were only fitted 3 years ago. Usually these outlast the joint but these have just perished away. Don't know where I bought them but I have another set in stock, an ebay purchase, that are the same make, so I won't be using them.
I also noted that one of the 4 rubber shrouds on the front brake caliper slides was damaged.
How the hell do you get these out without damaging them ? Does anyone know ? I had a quick look but they seem to be bonded into the caliper body. I have spare calipers with shrouds fitted so would like to do a repacement shroud swap if you say that this is possible.
From memory I vaguley remember;
I think the rubber gaiters have a lip that inserts into a recess in the body before the slide pin is inserted , so the pin holds them in and needs to be removed to get the rubber gaiter out of the recess if you get my drift?
Defender is right, although they may also be bonded as they do seem to be tricky to remove. Have you found a source of spare shrouds then?
Poor quality parts have been really annoying me over the last year or so too - I'm sick of the parts counter guys all coming out with the same line "They'll last you fine mate".
The lower engine mount on mine lasted just over a year and 15k miles before it ended up worse than the 160k mile 15 year old OE bush! :evil:
A bit like those pattern part strut pipes that last about 2yrs if your lucky :x
x 117
Yes Idid try to get one off with the slide removed but they seemed well and truly stuck in - - hence my post.
I have a couple of spare calipers I will check them out to test your advice out.
I wonder when they age they kinda get welded in? Look forward to seeing how you get on as i've got a few calipers that could do with an overhaul as the boots have perished etc....
