Oh dear the things i fixed today.
- x 27
:shock:Car is running sweet rotor arm was really, really worn out metal contact was non extistent plugs weren't in the best of health either surprised car was running at all just got the manifold to sort and mechanically its sorted. Front washer pump was A.W.O.L. dismantled washer bottle blew through pump tried again hey presto fully functioning again. I promise i won't swear again. I promise i won't swear again. I promise i won't swear again.......
messerschmitt owner
O.K.
th reason you might be swearing is useing that W S**T,
ignition components in good order should be clean and dry, as most things like the W stuff atracts dirt then in turn that atracts mousture, visiuos circle comes to mind
demag
- My Cars: BX 16v Ph2 - Jazz
BX 16v Ph2 - XPO - x 103
Rotor arm
