photos
photos
:oops: I know it's been asked a million times before but how do i get a photo onto here from photobucket. Picture is uploaded and ready to be sent do i type in bxclub.co.uk :?:
Stinkwheel
Post by Stinkwheel »
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
:oops: Read all that prior might as well be in klingon!! To be honest it would be quicker to print the photos and stick them in an envelope!! Not that i'm a luddite you understand :?
Stinkwheel
OK, so you know in photobucket you get the box below it?
they say things like 'direct link or 'img code'
You want the im code one....... highlight the whole thing and copy it using right click.
if you then right click and 'paste' that into your post where you want the pic it should work. Before you submit the post it should look something like this..........
**Image
hope that helps.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
Aha, the steaming CX! Or is that just a cloud of gas escaping? :wink:
Stinkwheel
Im willing to bet, with hindsight, it was actually a cloud of gas :?
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
scarecrow
Post by scarecrow »
I wish pictures of my car came out looking like that (even with the gas) :wink:
Why are cx engines perched so near the front? It cant be weight distribution, can it?
Stinkwheel
i doubt it scarecrow, they tend to be a bit front heavy (as found years ago when i put my first Gti Turbo on the ramps where i worked at the time. It actually only needed a gentle touch to make it rock forward on the support pads, lowered it again and stuffed some heavy stuff in the boot, much safer :) :)
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
