Wanted: LCD clock
Stinkwheel
Wanted: LCD clock
Dash LCD clock
anyone got one or two non workers or damaged cases or anything?
I would like to get hold of a couple to strip for parts that i can use on my CX to try something.
Cash monies or swapsies or stuff (but not things) available in exchange.
Ta.
Ta.
Doctor Of Gonzo Journalism!!!
93 BX TZD Estate
90 BX 14TE St Tropez
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
85 GSA saloon rally car
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
KevR
I'll have a look - almost certainly got one, might have two. Will look when it stops raining for long enough to get out to the barn without drowning...
Stinkwheel
Stinkwheel
TBH Mat i only want the actual LCD glass bit out of them. Hence why broken or damaged ones are fine.
Series 2 CX's have a 4 panel digital display that show water temp, oil temp, time and outside temp.
They always fail one way or another (hardly surprising after 23 years)
but mine seem to have lost the liquid from them, they all appear to be the same actual front glass unit. So im hpoin that the BX ones are the same and i can fashion a decent repair with the bits from old BX clocks.
Trying to find replacement complete units is rare for the CX and even rarer that they work and MIGHTY expensive when you do.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
KevR
Found one, might have another in the spares car down the field.
PM me your address and I'll send what I've got.
Whilst looking for that, came across some stuff I forgot I had, including some new old stock CX bits, if you happen to know of anyone who might be interested.
They include:
2 x water pumps
1 x complete clutch (2.5 diesel I think)
Four lumps of exhaust (two front boxes, two back boxes) - I might be able to decipher which model they're for given time. They're original Cit bits I think, not repro.
1 x estate rear wing/quarter panel - I forget which side.
Some other small stuff I can sort through if you like.
They include:
2 x water pumps
Stinkwheel
Kev, you're a star.
If you can and want to sort throuh the CX stuff i will post it up on the CX Club site if you like mate.
You will have PM in a moment.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
electrokid
Nah - got enough of them at the mo... Tabut best not mention that to electrokid otherwise he'll take it as a challenge!
Try cleaning the zebra strip and the PCB connections with... oooo.... some kind of alcohol - just a single wipe on the LCD itself because the connections can easily be worn out. Reassemble as it was designed - the pressure on the zebra strip can be very critical.They always fail one way or another
I like the new avatar Stinkwheel - LHM man
2002 C5 HDi SX estate
Stinkwheel
Ta on the avatar, its a great hero of mine, the late Hunter S Thompson.electrokid wrote:
I like the new avatar Stinkwheel - LHM man- excellent
As for the ribbin strips, ive no issues at all with how to clean it all up and re-assemble, i do that to LCD's on multi meters most days of the week. Its just the fact that the front LCD screens although not broken seem to have lost most of their liquid. I will try and get some pics tomorrow to illustrate the point.
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
93 BX TZD Estate
93 BX 19 TXD Estate
92 BX 16TXi
77 Ami 8 Break
79 Acadiane
81 Dyane6
84 2CV6
KevR
It's just occurred to me...
I assumed you were talking about BX clocks. Of which I've now found two. But BX clocks are LED not LCD...
Do you still want them?
I've made a list of the various CX, BX, AX and unidentified bits I've got, with part numbers where available. Will post it probably tomorrow in a couple of separate threads.
It's quite a long list!
electrokid
That is unusual - they usually start to delaminate and go black at the corners first. Maybe they have been - or are being blasted with DC - if there's a cap or caps in series with the LCD drive lines they might have gone leaky. I've seen a couple of batches of ceramic 0.1?F caps that only took a matter of months to become 500? resistors - used in quantity as powerline decouplers on a memory card that really screwed things up.mine seem to have lost the liquid from them
Mine is LCD with a bulb behind with a green filter - it looked like LED to me which is why I didn't try to fix it for ages (it would come on briefly if I was hammering it round a lefthander and caught a bump at the same time). When I did get around to fixing it I found it was just a bulb needing replacement.But BX clocks are LED not LCD...
KevR
Ah, that makes sense - it wouldn't need a bulb in the back if it was LED would it... I hadn't made the connection. Speaking of which, you wouldn't happen to know what connections I'd need to make on the back of one to wire it into a different vehicle would you? I've been toying with sticking one in the H van but was convinced I'd wire it up wrong and blow it to bits...electrokid wrote:
electrokid
I'm pretty sure it's just 3 - 0v / ground, a +12v from the battery which keeps the clock running when everything else is off, and a +12v which just drives the bulb - and on the BX is connected to 'ignition'.
As long as you get the 0v / ground connection right you won't pop anything because the other 2 wires are both +12v.
There are some reasonable aftermarket clocks which often have extras such as temp / ice warning etc - might be easier for the H van.
KevR
Just checked and there are four connections...
