"STOP" + Coolant light
Wooscary
Post by Wooscary »
Hello
So, driving today, had the above lights come on. Pulled over and had a look. Started car again, light off. Carry on. Later it comes on again, then goes off and on and off several times throughout the journey in quick succession.
I'm thinking it might be just at the level of the sensor and so sloshing around while driving over bumps is making the light come on.
Check header, water visible, topped up slightly.
Light still coming on randomly while driving.
Thoughts?
Martin
messerschmitt owner
Post by messerschmitt owner »
clean the connections - they may be dirty and may need a clean
properly check the coolant level and ensure it is OK
Citroen XM 2.1TD SX hatchback
Citroen XM 2.1TD VSX estate
Smart Roadster
Fiat Punto Cabriolet
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
BX-less at the moment!
Wooscary
Post by Wooscary »
Ok, sounds like a good idea. Not sure which connections, or where they are though. :D
And as far as correct coolant level goes, there appears to be a sort of bar around half way up inside the header tank, is that the fill level?
Thank you.
messerschmitt owner
yep that should be the fill level - can't remember on the bx but on the xm there is a plug/relay (brown) on the header tank and I assume it is the sensor for water level.
Smart Roadster
Messerschmitt Kr200
Bond minicar mk C
Fiat 126 Bis
Wooscary
Post by Wooscary »
That would make sense, I'll take a look.
Much appreciated.
