BX bits for sale - mostly new old stock
KevR
Post by KevR »
Having a bit of a garage clearout and have come across the following. Some I may keep, but otherwise open to offers if anything takes anyone's eye.
Some of it may not be BX - if anyone can identify any parts with a bit more precision!
I'm away most of this week, so won't be able to do anything about sending or answering questions 'til next week.
Please see other posts for CX and so far unidentified bits.
Complete clutch for 1.6 Petrol (I think). 200mm diameter. Brand new.
95 633 346 window channel guide x 2
95 635 518 shanked bolt
7XB 95 562 446 door handle x 2
7XB 95 569 837 door catch assembly
95 637 052 clips
95 643 658 rubber wossnames marked D + G (left and right)
7XB 95 586 610 rubber boot
95 632 291 mirror mount foam?
95 619 578 grey plastic trim
2XB 95 587 471 brake pads saloon BX rear x 8
95 634 943 acclerator cable BX diesel auto
96 081 712 clutch cable marked as BX 16
95 638 113 speedo upper cable
7551 3020 looks identical to above
?? starter motor from 1987 BX 16TRS (used)
?? alternator from 1987 BX 16TRS (used)
?? Front exhaust pipe. BX but not sure what model. x 2
NeilGP
Post by NeilGP »
I don't know the part number, but are these rubber bits the door windows seals?
I have lost one on the offside rear or my BX16 and cannot seem to find a replacement?
Thanks
KevR
Post by KevR »
Do you mean the:
"95 643 658 rubber wossnames marked D + G (left and right) " ?
Of so no, I don't think they're door window seals - I'll check but I seem to remember they're some kind of small rubber boot.
Which bit do you actually need - the scraper part that rubs against he window as the window rubs up and down, or the channel that the window closes into?
NeilGP
Post by NeilGP »
Yes, its the scraper that wipes the door glass on raise and lower, coupled with stopping rain water going in the door.
Neil
A476 RBX
Series 1 BX 16TRS
scarecrow
Post by scarecrow »
Hi - I'm interested in the strut kits - could you let me know the price please?
Steve
KevR
Post by KevR »
Ah, sorry, I should have removed them from the list - if they are indeed strut kits I'm going to hang onto them.
scarecrow
Post by scarecrow »
tease
