changing the heater blower motor
unblocking washer pipes
finding exactly what that strange clanking noise is under the car when you go over bumps
adjusting / changing the clutch cable
adjusting the exhaust so it's not rubbing on the trim
then your advice would be most gratefully received
you never know we may even convince my hubby to post on here
At least once we've finished (are you ever finished????) we should be able to start helping rather than just asking all the time,
thanks in advance
Sarah x
