To grille or not to grille
^^bx> What is the purpose of the grille on the rear quarter panels? ventilation! The foam inserts on mine have virtually disintegrated is it a hassle to replace it and if i leave it what are the consequences? :?
JayW
x 13
Post by JayW »
Cossequences = NIL... most of them have decintegrated by now, just don't aim the jetwash into them.
Access = Remove the rear plastic qtr panels (inside) and the internal "vent" is simply held in place by (IIRC) 2 10mm nuts. Although the foam can just be pulled out the top.
I *think* the foam is only there to reduce the chance of water ingress anyway.
x 103
The 'Vent' is a body exhaust, its is a fundamental requirement of the heater/blower box so that you don't get deep drumming caused by buffeted air hitting the front of the car, coming in through the blower and having no where to go.
All cars have them some where. Modern cars have them exiting onto the rear wheel. Here the foam (and usually a one way flap) is required to stop moisture, dirt, dust, road noise and temperature entering the car.
On the BX the foam is mostly for reducing road noise entry and as JayW says to reduce water ingress. That said the position of the exaust intake being in the boot, the road noise difference will be minimal.
Mike P
Post by Mike P »
On a connected subject, is there a technique to removing the inner C pillar trim :?:
IIRC there are 2 or 3 small pozi screws to take out, and then you have to slide the now 20 year brittle plastic off the trim clip.
This is the point where I am normally left with 2 bits of broken plastic in my hands :roll:
Mike P
x 103
Mike P wrote: This is the point where I am normally left with 2 bits of broken plastic in my hands :roll:
Me too, i've managed to get one off and back on once successfully, slammed the boot shut, had left a screw driver on the shelfy bit and snapped the tip off the trip some how. VERY annoying. Its still like that now!
JayW
x 13
Post by JayW »
Mike P wrote:On a connected subject, is there a technique to removing the inner C pillar trim :?:
Yes! It's really rather easy...
Find a magic lamp, rub it and ask the kind Genie to magic them off for you!
Oh hang on, did i say easy? Oooops, i meant no..... :lol:
Post by kiwi »
My soloution is
Dont Touch it Unless you Really Really Really have to.
It must be just me thats never had a problem then?
rayfenwick
Post by rayfenwick »
A hairdryer to warm the plastic would help, as would doing it when the car's nice and hot after being in the sun. A cold day definitely won't help.
(I have broken corners on mine.....) :shock:
Ray
www.citroencarclub.co.uk
