I need a set of good quality valve stem oil seals for a 1988 (late 88 TU/K1G engine, timing belt not chain, gearbox on end not underneath).
Also a good quality cam cover gasket.
Just thought someone might have some left over from a head set etc?
Thank you
Simon
Wanted: Valve stem oil seals 1.4 BX petrol
Thanks Roverman, I take your point, just want to fit some decent ones - not the sort of job one wants to do twice really...!Roverman wrote:I imagine as that engine is quite well used in the saxo 206 etc you should be able to get some cheap from a motor factors?
By the way, I like your car listing - saying which ones are taxed etc, I have a few machines lying in the sheds etc, don't list them as they definitely Seriously Off Road - SORN...
