19 TGD Estate
richardd1652
19 TGD Estate
Post by richardd1652 »
http://cgi.ebay.co.uk/1991-CITROEN-BX19 ... 3f037211b4
I seem to remember this ebay members user name.I think he broke a TXD auto a little while ago but will email and find out?
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
JayW
x 13
Post by JayW »
I've got a bid on it. Looks like just what i want!
Yes looks very nice , would have had a punt myself if it had been up North but then I spose Richard would of had it. :)
electrokid
Post by electrokid »
Yes it's Alex - I brought some bits of that one up to Gaydon for folks - and bought a few bits myself :-)
Jay - sending PM in 5
2002 C5 HDi SX estate
JayW
x 13
Post by JayW »
Had a cursory look at this earlier on my way back from Thorpe Park and it's not for me so i'll leave it for someone else.
richardd1652
What put you off Jay?
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
JayW
x 13
Post by JayW »
richardd1652 wrote:What put you off Jay?
Richard.
Apparently, everytime I give an appraisal of a motor i'm slagging the car or owner so i figured just saying "not for me" was more appropriate...
But as you ask:
It depends on what your priorities are on an old motor, mine are "If the body's straight I can fix the rest". This car's body is not straight, I don't think there was a straight panel on it and the wonky headlamp is due to it being o/s/front-ended though the wing has been somewhat straightened out.
It could well be ok if all you want is a cheap workhorse, but if you have to factor in a clutch change I make that £300 car + £70 clutch (if you DIY), £50 on bits & pieces & £50 on a test... All this assuming YOUR tester doesn't spot something the last one didn't.
I didn't look at the rest as it would have been a waste of the sellers time.
Like I said, not for me. Not being negative, just cutting through the Brie :wink:
richardd1652
Thanks Jay.I think i will leave it also.Its a long way away and although i am after a "nail" as a workhorse it doesnt have a towbar so that would need figuring in to the cost also.Wonder what it will do £113 at the moment with days to go?
Richard.
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
electrokid
I popped in to have a look at it this afternoon - it's not good - but I'll hold off posting about it's problems until I've chatted with Alex about one particular thing I found - he wasn't at the garage today.
In the meantime I'll list its good points...
No real signs of rust on the rear quarter panels.
Glovebox lid is present and one of the hinges isn't broken !
That's about it !
electrokid
If anyone is still going for this one here's a more comprehensive report...
Read the additions to Alex's listing in conjunction with this - basically if you want a tidy car suitable for washing in your driveway on a Sunday morning then there's a lot of work to do before it looks good. I would peg it as a spares car but someone with good bodywork skills could still save it.
OSF LHM leak evident - now apparently fixed - see listing.
A bump to the OSF has left the leading edge of the front wing in bad shape / corrosion - some evidence of this area pushed back slightly.
Front bumper OS not properly located in the square hole (rust ?) and no trim.
Front bumper NS no trim.
NSR door slight crease above trim line.
OSR door slight crease below trim line.
Rear bumper faded - small crack on OS and OS trim fitted with plastic rivets right through the trim itself.
Scratches to roof - 2 of them deep - 1 showing rust.
Will need a damn good clean inside.
Underbonnet looks tidy enough.
I couldn't see any rust on the rear quarter panels.
Glovebox lid one hinge broken.
Rear washer jet missing.
The cracked pedal box makes throttle operation a bit odd and it could also account for the heavy clutch.
It' doesn't sound that bad then? There's nothing there that would put me off buying it as a good work horse for the sort of money it is at the moment. But just a bit too far for us Northerners I think. (love the colour, looks great from here :lol: )
Most of the jobs sound a fairly easy fix, plus if your not bothered what it looks like then not a bad buy.
