washer jets
sarahjaneking
My Cars: 1993 Silver BX 1.7 TXD Turbo Hatch
1992 Black BX 1.7 TZD Turbo Hatch
2006 Silver C8 2.0 Hdi
washer jets
Post by sarahjaneking »
where can i get them from????? just cheated by putting mine on hubbies for the mot (still didn't pass b****r !!!) but I can't find any replacements anywhere????
thanks
sarah x :)
1993 Silver BX 1.7 TXD Turbo Hatch (although I don't know where it is - seriously!!!)
1992 Black BX 1.7 TZD Turbo Hatch (we've been apart for 3 years but now reunited)
^^bx> U tried stealers i'm struggling to get door seals for mine. How's Big Trak.
sarahjaneking
just put an enquiry on breakeryard, our local scrappie disappeared yonks ago :(
Big Trak is GREAT!!!!! :D :D but a little lonely so I've pre-ordered his younger brother to keep him company :oops:
scarecrow
Post by scarecrow »
The trouble with second hand ones is they'll as likely be blocked too.
Have you tried all the cleaning techniques? Failing that there's this thread: http://www.bxclub.co.uk/forum/viewtopic ... light=jets
Oscar
Post by Oscar »
I replaced them with crap ones from Halfrauds.
if they are still availible here is price and part No. from dealer
95495714 SPRAYING RAMP 13.36 GBP 15.70 GBP 15.70 GBP
scarecrow
Post by scarecrow »
This is better.... http://www.bxclub.co.uk/forum/viewtopic ... 405+washer
EDIT: than my previous link, I mean
I just clean them regularly, take them off & they have a small endcap on one end, carefully prise this off making sure it doesnt catapault off into oblivion. I then get a sowing needle & push that into the holes, & then i normally blow water through the tube with my mouth until the thing becomes clear, don't do that too much or you'll get dizzy :lol: That should hopefully sort it out.
Keeper of the site Goat
Post by cavmad »
Individual wires from a wire brush are also good for poking into washer jets but watch your fingers!
Vauxhall apologist.
I drilled the holes out to .8MM. No problems since.
GSF used to sell them for about £7 IIRC..
electrokid
Post by electrokid »
I used a small drill as well. Can't remember whether I drilled out new holes or looked for the original ones to clear - it was for the MOT 4 years ago and water wasn't reaching the top half of the screen so that was the only requirement from the task - not been a problem since.
2002 C5 HDi SX estate
i have offten thought of useing mig tourch liner to make up a new spray bar ,
like this if your good with very small drill bits and a hot air gun,
http://www.weldingtorchparts.co.uk/item ... liner.html
:idea: On my scania truck the spray bar is metal and simply clips onto wiper blade and then rubber pipe from washer. Occasionally detaches in winter if nozzles become blocked/frozen so i secure it with a cable tie. Might be worth popping into a scania dealer and trying one out would cost pence i would imagine. 8)
Discoil
Post by Discoil »
With the bx spraybar/tube I take out the end bung , slide the tube out of the clips . This allows the tube to be ( with a little persuasion ) held in a straight line. Use warm water or do on a warm day to prevent breakage or cracking.
Obtain a 1/16th welding rod and push it all the way through.followed by a blast of compressed air.
Reassemble all parts and test !
It works for me everytime.
Land Rover Discovery TD5
