My 19TGD has play in the power rack.Is it a bugger of a job to swap?
Richard.
19TGD Steering Rack
richardd1652
19TGD Steering Rack
1985 MK1 BX Digit
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
1986 MK1 BX Leader
1988 19RD
1983 Tin Snail
- x 94
Not too bad on a 1.9 n/a diesel. Would be easier access wise if you remove the exhaust downpipe first. Otherwise not really too bad IMO. Biggest ball-ache will be getting the hardy disc undone from the column and possible undoing the pipes, as you\'ll be reaching up and feeling for them. I\'d pull it out the driver\'s side too, but then I did mine with the engine out. Got pics if you need them.
I've done a few recently, and, as with most things, the more you do the quicker the job gets.
The biggest arse of the whole job is the two pipes in the side of the pinion.
Not too bad on a NA but an utter arse on a TD, I know not why since they are the t'other side from the blower, but still, an utter ballache.
You can actually get the rack out, and back in without removing the ram, but you will need to remove the gear selector swivel off the top.
